M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI
Rough Idle After Oil Change
Old 09-13-2013, 12:28 PM
RayGon's Avatar
1999 ML320 Elegance
I had a recent oil change on my 1999 ML320 with 91,xxx kilometers (about less than 57,xxx miles). I noticed that ever since that oil change, my idling when engine is still cold, has been a bit erratic and rough. It eventually idles better as the engine warms up. Any comments or anything that I should be looking at? If the oil level is somewhat over the maximum, will it cause rough idling?
RayGon is offline
Old 09-13-2013, 05:27 PM
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
With the many warnings regarding the ill effects of overfilling the oil it appears that you are willing to gamble on the amount that will cause extensive damage to your engine when the corrective measure is extremely simple. Suck out the excessive oil.
Mike
Mike's ML is offline
Old 09-13-2013, 05:34 PM
RayGon's Avatar
1999 ML320 Elegance
Thank you, Mike. I will have the excess oil sucked out. I actually found out that it was over the MAX level just the other day. I should check the oil level regularly and more often even after a new oil change.
RayGon is offline
Quick Reply: Rough Idle After Oil Change
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
