ML320 stuck in limp mode or low range
Old Apr 12, 2014 | 01:16 PM
dylanroach's Avatar
mercedes ml320
Hi ALL, I need help. I have a Mercedes ML320 petrol year 2000 (X). I think it is either stuck in limp mode or in low range. Basically it won't shift from first gear, I will explain everything from the point of turning on the ignition key. So when I, turn the jeep ignition on a alarm sounds and the low range light flashes for about 5-8 seconds then it stops and light goes out, I have gone through the reset thing and I can't get the light to stay on, ABS, EBS warning lights and another 2 warning lights also stay on. Could it be the low range switch itself had gone ??
To date I have done the following to try and resolve to problem;
Changed various sensors,
Changed the shift control transfer motor,
Changed the shift transfer module,
Fully serviced the gearbox,
Fitted new battery,
The problem still remains
