Random emergency calls draining my battery!
Old Apr 27, 2014 | 11:27 AM
sit's Avatar
sit
ML320 Model 2002
Hi all,
I´m experiencing that my radiosystem is initiating random emergency calls and recently it has drained the battery after standstill in the garage for a couple of days. I recharged the battery and the same happened! When I reconnect the battery everything looks ok but after some minutes the radio begins initiating the emergency calls and this procedure seems drains my battery over nigth?
Any suggestions on how to disable the emergency call initiation depply appreciated.
Regards, Gary
Old May 2, 2014 | 09:10 AM
DrX's Avatar
DrX
2002 ML320, 2003 A160
TeleAid makes emergency calls in response to constant analysis of data from various inputs. Situations including SRS deployment, glass breakage, tailgate opening while not stationary, or vehicle on its side will trigger an E-call. So will faults in any of these systems or sensors.
It should be possible to deactivate the TeleAid module using MB's Star Diagnosis computer, which you can have performed at an authorized MB workshop.
Old May 8, 2014 | 07:29 PM
sit's Avatar
sit
ML320 Model 2002
Hello DrX and thank´s for your reply.
I had an accident on my car prior to this where I was hit in the rear by another car. This didn´t trigger the emergency call but might be the reason for this annoying problem. I´m taking the car to the workshop to have it diagnosed.
Regards, Gary
