ML 320 Remote Control key entry
If I had a key battery issue I would remove the batteries, flush out the inside of the case with WD40 followed by a distilled water rinse while exercising the key buttons to try and free up whatever is staying on / shorted, causing the battery drain. Then before replacing the batteries I would tighten up the battery connections inside the key fob case. That has also been a minor problem in the past. Weak battery connections have been mistaken for week or dead batteries.
Mike
Mike
