Need Help ASAP PLZ - 2002 Halogen Install
Old Dec 19, 2003 | 06:14 PM
haild's Avatar
ml430
Hey guys,
I installed the 2002 Halogen lights on my ML 2000 and now the high beams stay on all the time. The low beams + High Beams come on when I turn handle up one click. Also nothing happens when i push the handle in for a quick flash of the high beams being that they stay on all the time. Even when I push the lever in for a quick high beam flash, nothing happens.
I did not use the pigtail adapter, i was told by Auto class that all i need to do is swap the foglight wire (gray) with the low beam (pink) inside the truck harness. That is what i did. Im thinking i possible swapped the wrong wires....
Can someone please help me as i do not want to drive the truck at night with the high beams on all the time.
Thanks alot in advance.....
Old Dec 19, 2003 | 07:17 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Need Help ASAP PLZ - 2002 Halogen Install
Originally posted by haild
Hey guys,
If Autoclass sold you the lights, can't they help you fix the problem? Seems like it would get you on the road faster!
Or, if you think you swapped the wrong wires... can't you swap the right ones?
-s-
