I knoweverything there is to know about the ML
#77
ml359 help
hey I need to find some one to do work on my ml350 do you have anyone you can recommend in queens,ny plaese help the dealers here suck and my local mechanic either chatges too much money or breaks thing without me knowing!
#78
just bought an 06 ml350. some say 4matic but mine doesnt. is it still 4wd? if so whats the difference between 4wd and 4matic?
#80
Help... my '98 ml320 is making a humming noise. Its coming from the rear end, sounds like the wheel bearings. I've changed them but still makes same noise. Then I adjusted the rear E barkes, cleaned the sidling point and greased them with white litheum. Then replaced the rear brake pads and still makes noise. Wordering if it is the driveshaft support bearing or any suggestions to my ploblem. Other than the noise the car drives fine.
#82
Only time my ML has ever made a strange noise from the rear was the E brake and a bad wheel bearing. Time to bring it in to a good independent shop!
#83
im new to this but here it goes i gave my ml320 to my son and he let the car sit with a dead battery for 3 months he replace the battery now the truck will not start no power no horn nothing is there something you need to do i took the battery back and still same problem help
#84
1999 ML430 Service Engine light
Hi, I have a 1999 ML430 162k
Light came on,stalls sometimes coming back to idle at a stop, also hesitates upon rapid acceleration sometimes, otherwise runs fine.
replaced fuel pump and filter, and catalytic convertors,crank sensor.
What do you think?
What do you think?
#86
Hi ML God I have a question,
I have a 00 ML320, It has a black cap on the roof where the antenna should be, I purchased the antenna on ebay, How do I remove the cap and install the antenna? & Also I have a cd Nav drive for the MCS, After installing it into the MCS do i need a amplifier or something or will i just attach a wire that already exists behind the mcs which leads to the roof antenna (In my case, the little black cap) ?
Sorry actually two questions :
Speaking of little black caps, My key (Buttons) stopped working, I tried batteries resync, nothing works. I've been removing and replacing the little black key hole cap in the drivers door every time I enter or exit the vehicle. I was wondering do the caps protect the lock from water or something or is it just for show?
#89
ML430, Mini Cooper S and Porsche 911 Twin Turbo
For the love of god....
no not ML god - will somebody lock this thread ?
ML god hasn't posted here for years but this thread just won't die.....
#93
HI. Are you still in the business?
[I have an ML 500 2003 model and I love the way it moves now. I wish it remains like so. What do i do to maintain its good behavior????
thanks
thanks
#94
I noticed today that my wiper isnt working..the water will squirt out but the wiper doesn't move. Do you think I will need a new wiper motor?? This is the first time it's done it ! Also..my check engine light keeps coming on. It will go off sometimes but then comes back on. Not really sure what the problem is. Any ideas? Thanks
Oh..its a 99 ML320 with 164,000...
Thanks in advance!
Thanks in advance!
#95
'00 ML 430
I think it is Very brave to ofer help us a bunch of amateur owners trying to get car fixed by themselves first... Just couldn't understand why some people misread it as chanse to chant
about manufacturer.
here is my question: How can you electricaly check Steering angle sensor giving C1140 how do I make sure I must take it to service as I can't replace column jacket and so on myself.
Thanks in advance.
crazy Ivan
about manufacturer.
Thanks in advance.
crazy Ivan
#100
The moderator must not check this thread at all, or else he/she has a perverse sense of humor. Prolonging the agony and futility of this thread is just cruel. There are no answers here. ML God is an urban legend. No one home. Go to the main forum and ask questions.
If there is a moderator, PLEASE close off this thread!
