anyone have a write up on installing xenons?
Old Feb 13, 2004 | 01:59 AM
98sclass's Avatar
do i only have to splice/solder the positive wire from the ballast to the positive white wire on the headlight and the negative wire from the ballast to the brownish negative wire?
Old Feb 15, 2004 | 02:13 PM
Benza's Avatar
ML 320
Adapters
If you have the adapters there is no need for spliceing or soldering. It's just plug and play
Old Feb 16, 2004 | 01:20 AM
98sclass's Avatar
sorry, but what kind of adapater is that?
Old Feb 16, 2004 | 02:16 PM
Benza's Avatar
ML 320
Bixenon Adapter
It's the adapter's for the bixenons. I allows your OEM headlight wire harness to plug into your Bixenons without splicing. Your xenons should have came with it but if they didn't there are places that sell them. Try www.performanceproducts.com
Old Feb 17, 2004 | 03:18 AM
98sclass's Avatar
Re: Bixenon Adapter
interesting... do you think they would work for an oem audi ballast?
Old Feb 18, 2004 | 12:58 AM
Benza's Avatar
ML 320
Re: Re: Bixenon Adapter
I don't think so.
Are you installing oem Audi lights in your OEM headlight housing on an ML?
Old Feb 18, 2004 | 01:07 AM
98sclass's Avatar
Re: Re: Re: Bixenon Adapter
I don't think so.
im trying to install oem s4 ballst into my 98 sclass and crossposted on the other models to get more feedback.
Old Feb 22, 2004 | 10:08 AM
Benza's Avatar
ML 320
I doubt it. If you are looking to retrofit bxenons contact:
HIDTECH
They retrofitted them into my Hummer and did a great job.
Maybe they can help you.
