Noisy Power Steering Pump
Step one is to order a reservoir, 2 O-rings (in case you damage the first one on installation) and locking C-clip. If you do not order OE parts from the dealer you will have leaks at the res. and the screen will fail again.
Step two, after receiving the parts, is to choose a location where you can install the new res. and be able to raise both front wheels off the ground. You cannot start the eng. after installing the new res.
Suction out all of the fluid in the res. Then remove the C-clip and follow instructions for removal & installation.
After the installation and partial filling do not start the engine. Raise front wheels off the ground, turn the key to pos. #2 (DO NOT START THE ENGINE) and follow bleeding procedure in pdf with aid of someone looking into the open reservoir until all bubble are eliminated.
