M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI
V6 vibration as rpm increases???
Old 02-28-2004, 08:26 PM
ML 320 2000
My 00 ML 320 V6 motor alwas seems to get harsh or vibrate as the rpm increases, is this normal? Alwas seemed to do this from new.
It doesn not spin freely in a smooth mannor but I have alwas just though this was the V6 design limitations.
Thanks!!!
Keith
00ML Keith is offline
Old 02-28-2004, 10:55 PM
2020 GLE 450; 2015 BMW M4 Coupe
Engine vibrations
My '98 has never vibrated. It's puzzling that you say it's been that way since new. If not, I'd say check the harmonic balancer or engine mounts.
Don't know what else to suggest. Have the dealer check it out. Still under warranty?
GregW / Oregon is offline
Old 02-29-2004, 02:17 AM
ML 320 2000
Thanks Greg,
More like it gets a bit buzzzzy as the rpms increase.
Just attribuite it to the V6 design as they are not by nature a smoooth motor.
However, if it has ballance shaft(s) (???)it should be smooth to red line I would think.
I had a wine that was like a transmission wine sence new then last monthe the dealer made it go away by replacing the belt or pully or somthing so I just don't know what to accept as normal.
Biggest irritation is the wind noise from the windsheld area.
Thanks Keith
Old 02-29-2004, 04:20 PM
a car that can't do the throttle reset.
i think the vibration is normal...my 2000 320 does it too. but i have to say, my 98 didnt do it. im still pretty confident that its normal.
pointman is offline
Old 02-29-2004, 04:40 PM
ML 320 2000
ahopter,
Thanks!
Again, it is more of a buzz than a vibration.
It gets the job done!
Just would not expect people in the E320's et al, to be happy with a motor that sounds kind of buzzy when one would expect it to sound more sweet in the higher revs!
Keith
00ML, WT/bk cloth & SR
18" Carlssons w 30" Cross Terrain's
Old 02-29-2004, 05:02 PM
UncAl's Avatar
1998 ML-320
V6 vibration
I agree with Greg - it might be the harmonic balancer or engine mounts.
I'd have it checked. If its the harmonic balancer, it will pay you to fix it now. When it goes, it could rip up your engine pretty bad. I've heard of $2k repair bills.
UncAl is offline
Old 02-29-2004, 07:02 PM
2000 ML320 2006 SLK 350
I would check the motor mounts and harmonic balancer..
I had the same symptom on my 2000 ML320...mild vibration especially on cold starts.
They checked it at the last service...and recommended changing the motor mounts...said my harmonic balancer was fine..
Since they changed the motor mounts..the vibration is gone..
mihir_d is online now
Old 02-29-2004, 09:49 PM
just curious, how can the harmonic balancer cause vibration in higher rpm's?
pointman is offline
Old 03-06-2004, 12:48 AM
w210 e55
My 03" 350 has this behavior when winding the motor out. Right before the 1-2, 2-3 and 3-4 shifts at approx 5gs, the motor sounds like a lawnmower. As far as I know this is inherent in the build of the the v6. The ML500's I drove did not wind out like this.
A
Driver55er is offline
Old 03-06-2004, 04:48 PM
ML 320 2000
Thanks all, will keep the ballanceer & motor mounts in mind.
Good to know about the balancer weakness.
Driver55er , You prety much comfirm my feeling that it is the V6 design that is very dificult to make smooth.
Do we have ballance shafts? I don't know that we do.
Keith
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: V6 vibration as rpm increases???
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
