2000 ML 320 12v outlets / cig lighter not working
I had been using the 12v outlet under the glove box - had never user the rear compartment 12v or cig lighter - when the under glove outlet went out I tried all 3 - none work now. Replaced the under glove 12v outlet as pieces seemed loose - no help. Fuses are good - under hood for rear 12v and cig lighter and passenger well fuse for the under glove outlet. Is there a relay that controls all? Other ideas? Thanks.
1 Attachment(s)
Please UPDATE YOUR PROFILE in USER CP to include the year of the ML.
1 Attachment(s)
To use the cigar lighter the key must be in pos. #2 or the eng. running and is controlled by fuse #2 in the R/S kick panel fuse box.
Both the front and rear 12v sockets are hot at all times. Front socket is controlled by fuse #6 in R/S kick panel fuse box & the rear socket is controlled by fuse #17 in the underhood fuse box. |
Thanks - all fuses looked good but I replaced them anyway. I replaced the front R/S 12v outlet as parts seemed loose. No success. Could there be a relay that controls all three? Any other idea is appreciated.
https://cimg3.ibsrv.net/gimg/www.mbw...b789c0e2fa.jpg
https://cimg2.ibsrv.net/gimg/www.mbw...0bc6077033.jpg
Originally Posted by johnnyfos
(Post 7278793)
https://www.google.com/search?q=how+to+use+a+test+light+on+fuses&sa=X&ved =0ahUKEwj7i9aMx9vWAhVK2SYKHaoRCg8Q1QIIlAEoAA&biw=1 108&bih=630#kpvalbx=0 There is no relay, they are fed directly. |
