M-Class (W163) 1998-2005: ML 230, ML 320, ML 350, ML 400 CDI, ML 430, ML 500, ML 270 CDI
Steering wheel squeaks,inside the car.
Old 10-19-2017, 09:45 PM
Restoring 01 ML55AMG, Wife driving 05 ML350. I drive 01 ML55AMG, and my Beauty 1996 Mercedes S320
Hey guys, my 05 ml350 steering wheel squeaks inside the car when im turning, its not the power steering pump. Sounds like rubber seal squeak somewhere under the dash or something. Only happens when i start driving and then after driving for few minuets it goes away. Any idea what should i look for and how to get rid of it, kinda annoying. Thanks
IgorE350 is offline
Old 10-20-2017, 03:50 AM
2002 ML 320 & 2006 ML500
The problem is usually caused by a dry upper bearing, which is not replaceable.
Remove the Air Bag, then the Steering Wheel and then the Clock Spring and lubricate the top bearing with WD40.
Do not try to turn the steering wheel with the battery connected unless you have a scanner that can read and erase the codes.
File Type: pdf
File Type: pdf
Maj. Dundee is offline
Old 10-20-2017, 07:26 PM
Thumbs up
Sounds about right, but why would it sound like its rubber squeaking? ill do it sometime next week and let you know how it goes. THank you for quick respond and help !!
IgorE350 is offline
Old 10-21-2017, 04:56 AM
How am I supposed to know what it sounds like without hearing it? I can only suggest what I believe it is.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
