power steering fluid in coolant tank
Old 01-06-2018, 01:57 PM
zzr1400's Avatar
ml 270cdi
Hi I have a ML270 cdi
it appears to be power steering fluid in the coolant expansion tank can anyone tell me if this is a known problem and any which component has failed.
Old 01-06-2018, 02:49 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Is the power steering reservoir empty? It can also be transmission fluid.
Regardless, your radiator must be replaced.
Old 01-06-2018, 04:35 PM
zzr1400's Avatar
ml 270cdi
Firstly thanks for responding !!!
the resovoir is not empty and both fluids look the same.
I have a replacement radiator and will change it first and hopefully this will cure the issue.
many thanks Sir
Old 01-06-2018, 09:56 PM
The engine must be completely flushed and number of times with water until all traces of the oil is gone.
Quick Reply: power steering fluid in coolant tank
