runs then dies
2001 ML430 sport
runs then dies
I have a 2001 ml430 and my car will start up fine and drive but then it shuts off with no warning. Then I try to start it up again and it will crank over but usually I have to sit and wait about 30 min before it starts back up. , it shut off while I was driving it and now it won't start.
It could be the Crankshaft Position Sensor or a fuel issue. Have the codes read with a scanner and see if code P0335 or P2034 is stored, depending on which scanner you use.
