2005 ML350 roof antenna Replacement procedure
Old Dec 3, 2018 | 12:59 PM
1stChendeng's Avatar
2005 ML350 Sport
As the title states, I have a 2005 ML350 the roof antenna broke off. I purchased a new OEM part. Looking for the procedure for replacement. Any help will be appreciated
Old Dec 3, 2018 | 02:39 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
As of MY 2002, they used a one piece antenna and requires the removal/lowering of the headliner.
File Type: pdf
File Type: pdf
Old Dec 11, 2018 | 06:01 PM
demichae's Avatar
1999 ML430
I have never installed one, but I've removed about 20 from wrecked MLs. You first remove the plastic trim that borders the ceiling where it meets the rear hatch. That will expose the headliner. The next trick is to get under the headliner without ripping it. (I believe there are two large plastic bolts that can be removed).
You'll see three wires that need to be unplugged, and you'll then need to unscrew the large bolt with a socket (can't remember size, possibly 16mm). Once that comes off, hopefully the black plastic ring inside it comes off as well, and you can then pull the old antenna from the roof.
Getting under the headliner, without removing the entire thing (which is a nightmare job), is the only tricky part. I talked with a Mercedes mechanic who said they used to fix the sunroofs on MLs by putting a 2x4 between the headliner and the roof while working on it...I wouldn't do that, but it's one technique. I might be removing one this thursday, so I'll video what I'm talking about, which should make it a lot clearer.
Old Dec 14, 2018 | 04:19 PM
demichae's Avatar
1999 ML430
I shot a quick video of how you access the screw holding the antenna to the roof. You can watch it here:
Old Dec 14, 2018 | 04:21 PM
demichae's Avatar
1999 ML430
Just to clarify, I'm using a large screw driver because the ML is in the junk yard...you'll obviously want to be more careful when removing the trim and the plastic screw holding the headliner in!
Old Sep 28, 2020 | 08:54 PM
ChrisVannoy's Avatar
2002 Cl500
I was at the yard today and the two I found didn’t have a nut to remove it was a weird slotted fastener almost like a wheel lock I’ll get pics for you
