Newbie with a coolant dash on
Hi,
New to this forum, not new to Mercedes. I have a 1999 ML 320. The coolant dash light comes on after 5 minutes of driving and then will go off. For a 20 minute drive, the light may come on three to five times. The reserve tank against the firewall is full. No leaks that I can see. The temp is running at 90 degrees or a tad less. The water pump was replaced about 6 months ago, that was a drip leak back then. My mechanic pressure tested the coolant system, no leak. My concern is I smelled a whiff of coolant maybe twice in a month after parked and turned off. Again, no leaks. The mechanic was saying it may be an old radiator or heater core. Any suggestions? Thanks. |
1 Attachment(s)
Try removing the cabin air filter and see if it is wet with coolant.
Originally Posted by Maj. Dundee
(Post 7692287)
