MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   M-Class (W163) (https://mbworld.org/forums/m-class-w163-10/)
-   -   99 ML430 Driver's Side Rear Window Removal (https://mbworld.org/forums/m-class-w163/739865-99-ml430-drivers-side-rear-window-removal.html)
kyleml430 03-26-2019 08:27 PM
I have a 99 ML430 (which I absolutely love by the way). I need to remove the door actuator on the rear driver's side door in order to replace the spring, as it is currently machine gunning. In order to do so, I need to remove the window divider, and in order to do that, I must remove the window. Does anyone know if removal of the window regulator is necessary to remove the window? The 99's do not have air bags in the rear doors.
I am willing to post pictures if needed!
Maj. Dundee 03-27-2019 05:34 AM
3 Attachment(s)
Here are the instructions.
gkrumian 03-28-2019 07:00 PM
As far as I remember, I don't believe the regulator needs to come out. There's a bolt at the bottom of the glass that attaches to the regulator. If you undo it the glass should be free.
© 2019 MH Sub I, LLC dba Internet Brands
