Transmission stuck in 2nd gear. Need help
Have a 99 Ml320
transmission would occationally lock lock up in 3rd gear and I could reset it by turning the car on and off. now it is stuck in 2nd gear. Even when I turn the car on and off again. i decided to replace the transmission plate all the solenoids transmission connector plug. i also checked the tcm and plug for oil and both are dry. i tried erasing the codes with a snap on but codes are still present and it does not unlock the transmission |
What scanner are you using?
It sounds like you do not have a correct scanner to clear the codes. |
Snap on Solus ultra.Snap on solus ultraTCM codes Before I cleared the codes these were the codes 013 speed sensor n3 y3/6l1 109 speed sensor n3 y3/6l1 132 ecm can communication or ect implausible 135 can communication disturbed: engine management after erasing I got these codes and now it’s stuck on these codes no matter how many times I erase the codes 005 pwm valve y3/6y6 torque converter lock up 101 pwm valve y3/6y6 torque converter lock up These are engine codes P0715 |
