Putting A 430 Ecu In A Ml 320
Old Sep 24, 2004 | 03:13 AM
boyce_C's Avatar
ml 320
i have i 1998 ml 320 and whant to put a 430 ECU in rather than the stock will this work the cid bore stroke are the same...430's got like 50 Hp and 50 lbs difference
Old Sep 24, 2004 | 05:33 AM
autogunner's Avatar
You will have to change the Cat converters, you might have to change the trans., torque converter, rear struts, engine control unit, efan, trans. cooling lines and move the left motor mount one space. Autogunner.
Old Sep 24, 2004 | 09:29 AM
00ML430 Bulldog's Avatar
2000 ML430
Don't forget to add ML430 eight cylinder motor.
Old Sep 24, 2004 | 12:56 PM
pointman's Avatar
a car that can't do the throttle reset.
dont bother.
Old Sep 24, 2004 | 02:59 PM
dasMafia's Avatar
2000 BMW Z3 2.3 Roadster (hardtop current ly attached)
wow... clueless.
Old Sep 24, 2004 | 06:37 PM
Darkmann's Avatar
ML
Theoretically it should work. The computer takes input from the engine and the driver to perform all it's controls. You will not get more power than necessary. I believe the tranny has a separate control unit (someone correct me if I'm wrong here) so I won't worry about the shift points changing. The only issue I see is if the computer is coded for a 430 via the VIn or some other method, then if there's no confirmation from the truck, the computer may shut down. I doubt they'll do this though. Try it. If it doesn't work, reswap.
Old Sep 24, 2004 | 07:02 PM
boyce_C's Avatar
ml 320
yah you can match it all together ive dealt with the issue i but a new motor trans and converter in and had the match each one to the other then to the ecu
p.s i know i know just get a new ML but me and this ml have gone to hell and back twice and i love this one
Old Sep 24, 2004 | 11:07 PM
pointman's Avatar
if you love, then dont mess with it. if youre gonna mod it, and you love it so much, do it right... instead of pinching pennies on something you LOVE.
Old Sep 25, 2004 | 02:44 AM
boyce_C's Avatar
ml 320
cause i whant the most power to at a sarting besides hen the motor blow's after 400k and the trans licks it and your hanger bearing bits rapping the drive line around the hanger rippin off the mounts ( not from poor matence ) im already into it more than you belive so yah im watchin how much goes into it
Old Sep 25, 2004 | 08:18 PM
pointman's Avatar
i'm sorry, not trying to be rude... but i didnt understand any of your previous post.
Old Sep 25, 2004 | 10:12 PM
kostas's Avatar
2008 BMW 335xi Coupe
if you love it that much that you dont wanna buy a new one.. then just swap in a new 5.0L V8.. ratehr than these little things that dont really add any power
