N47 ABS Anti Lock Brake Pump Module help please
Old Apr 14, 2022 | 08:22 PM
jcb928's Avatar
1991 500SL
I recently bought a 2003 ML350 that is stuck in limp mode with most of the dash lights on.
Searching this forum I am 95% sure it is the N47 ABS Anti Lock Brake Pump Module on the abs pump
MB Icarsoft scanner shows,
Dtc esm
P1876 The signals sent by control unit N47 for the wheel speeds and braking torque are not available on the CAN bus
P187601
P192800
P192800
Looking online most seem to show a part number and barcode on the back but on mine it is just black with no part number. How can I find out the right module to order? I did visually check the plug and wires and they look ok.
Old Apr 14, 2022 | 08:32 PM
jcb928's Avatar
1991 500SL
Long Day
it was just caked in grime
Old Apr 15, 2022 | 07:16 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
jcb928 , the codes that you posted indicates that you only have a code reader and and not a scanner
Below are the correct fault codes for your vehicle.
File Type: pdf
