Running Boards Suggestions
I have a ML320 /2001 and I am looking for Running Boards ..
Any suggestions for DIY or get it from the Dealer.... lighted \no lights
any body do it before.. associated Costs etc., ??
Please shed light
Thanx
Please shed light
ThanxThen I found a company that custom makes running boards for the ML for under $300 (or an extra $100 if you want them painted to match) and that includes shipping to your door. So I bought them and installed them myself. I'm very happy with them, especially that I saved well over $1000. These are my observations about the aftermarket versions:
1. They're made of fiberglass, not ABS plastic.
2. The paint matched exactly to my silver ML
3. Installation was tricky and required a second person to hold it while drilling.
4. Required a little re-tightening of the screws a coupla weeks after install.
5. Looked a little sportier than factory RBs
6. Had a bunch of extra cash for booze and women (no, no i'm married)
Anyway, I think it's an awsome deal. I got them from www.runningboardwarehouse.com.
hope this helps.
Hecdog.. where do you get the instructions for installation ???
As far as installing them, the instructions came with the running boards and it was pretty easy, although tricky. The installation SaturnStyl is talking about is in fact difficult, but that applies only to the factory running boards where, and correct me if i'm wrong, you have to remove the rocker panel to install. These install much easier. No need to remove the rocker. They simple bolt on underneath it and have L brackets to support them and a cross brace to attach them to the chassis of the car. They provide all the hardware, all you need is a good drill and ratchet set. (I highly reccommend an angle drill--90 degrees to make it even easier).
Hope this helps. good luck.
Step 1: Grab the rocker panel firmly.
Step 2: Pull really hard.
Step 3: Repeat on other side.
I had to replace the rockers on mine because way back in october '03 when I did the PDI, I put some black step bars on it. I removed all the accessories when I bought it, because I either couldn't afford them or thought they looked stupid. The bars had warped the rockers and after several months they had not straightened out. I put on a new set under warranty :v
I have an extra set of desert silver rockers that are brand new I kept off my last running board job, just in case. I can have them painted should I ever need them.
I know I am rambling but here goes:
Its quite funny, how back in october '03 I accessorized and PDI'd this '04 ML500. I did all the things in my usual manner, and never in a million years would I have thought that the following march I would be driving it home. It had 180 miles or so on it, and then sat for so long the battery had died. I was inquiring about the purchase of one, and nobody even knew we had it on the lot anymore. They did a search of all the dealers online for a silver ML500, and hey wait a minute... there is one on our lot!!! Got the keys, found it, checked it out. To my surprise I had done the PDI and accessories!!!!! It had black step bars, black pinstripes, a sunroof bubble, car cover, sunshade, cargo liner and nets, all weather mats, and a front liscense plate bracket. No worries with this unit then! I jumped it off, and parked it out back. I worked on it over the next week in my spare time, taking off accessories and putting in a new battery. I added a few special touches here and there, and got a free set of all weather mats. I took off the step bars, and installed them on another ML, being careful to swap the underbody shields that had to be cut to install the step bars so you couldn't tell anything had ever been done.
I put the word out for a cd changer, and 2 "fell in to my lap". I installed it, having only to buy a bracket to mount it. I had thrown away the very bracket I had needed a month prior, thinking I would never need it. Cost me $40.00. Over the next few weeks I added the accessories I wanted, including a mercedes DVD rear seat entertainment system, and a cargo area liner. I performed every single update available to that truck also.
Anyhow the moral of the story is always do everything to the best of your ability because someday you might own that vehicle.
All I care is they have to help my kid get into the Truck with Ease ... he complains too much these days while getting in and out. saying it is too high for him..
Ofcourse the COST and the DIY matters to me toooo..
Thanks for all you suggestions..
That was the reason I chose one with running boards. It's a milestone for her, and it's going to save my back.
They're also good for doing up your shoes, e.g. after you've been to the beach.
Only downside is reduced ground clearance. They're not an off-road accessory. I can still drive up a median strip if I approach at an acute angle.
