Mud Flaps
Old Feb 9, 2008 | 05:44 PM
cschmelz's Avatar
2007 ML320 CDI
Mud Flaps
How hard is the W164 install for the MBenz mud flaps? I actually like the look and really would like to reduce the amount of spray kicked up on the sides of the vehicle during our vicious/salty winters.
Old Feb 10, 2008 | 08:37 AM
m1kefries's Avatar
2007 ML 320 CDI, 1999 C43 AMG
I installed them myself and they are quite easy to install. Just take your time on positioning and follow the instructions.
Old Feb 10, 2008 | 04:41 PM
NLRL's Avatar
2003 MERCEDES C230, 2008 ML 350
Where did you buy them from?
Old Feb 10, 2008 | 05:41 PM
cschmelz's Avatar
2007 ML320 CDI
If you haven't ever seen www.dealerfit.com you should check it out! Genuine MBenz accessories at a significant discount!
Old Feb 10, 2008 | 10:57 PM
NLRL's Avatar
Thank you
Old Feb 12, 2008 | 06:15 PM
m1kefries's Avatar
My wife bought them from the dealer as a birthday present. I looked at the cost from the dealer and thought they wanted way too much for them. I was in the process of looking for cheaper options when they showed up under my Birthday tree..... Everything is pay to play with MB..
Old Feb 12, 2008 | 07:03 PM
cschmelz's Avatar
2007 ML320 CDI
Well, that is why you don't buy them from the dealership. You can get the same parts (from Mercedes) online and save quite a bundle if you do a little research. eBay, dealerfit, etc. have helped level the playing field a little bit at least and given us some relief from the often huge dealer markups!
Old Feb 12, 2008 | 07:47 PM
CK530's Avatar
BMW 530
Cschmelz, have you purchase your mud flaps yet? Have you ever purchase thru dealerfit.com? Seems like a good reliable company. I'm looking to purchase the rear mud flaps and wheel lock.
By the way, thanks for the suggestion regarding my SAT radio's activation.
Old Feb 13, 2008 | 12:28 AM
cschmelz's Avatar
2007 ML320 CDI
I haven't bought them yet, but I HAVE purchased accessories for my previous Volvos from them and they are as advertised. They shipped quickly and were, well, simply the EXACT same as the dealer accessories but cheaper!
Old Mar 8, 2008 | 10:18 AM
gawdfatha's Avatar
2007 ML320 CDI (P3 package)
Agree about DealerFit. I was able to find some OEM front and rear flaps on Ebay for $225. They were pretty easy to install -- took maybe 2.5 hours. Despite the MB instructions, which must have been written on an Enigma machine , you do not need to remove any of the wheels. All you need is a short angled Phillips screwdriver that will fit between the tire and wheel well to tighten the screws.
IMHO, MB ought to consider installing the mud flaps on every ML at the factory ...
good luck,
gawdfatha
Old Mar 8, 2008 | 07:31 PM
w2hmh's Avatar
2008 ML320 CDI
I just got my ML320 CDI yesterday and the dealer mudflaps in a box....what did you use to clean the surfaces with...the instructions call for "Terostat cleaning agent"....
Old Mar 10, 2008 | 12:58 AM
CK530's Avatar
BMW 530
I have couple of questions regard the mud flap (rear only) that I have ordered from dealerfit.com. In the instruction manual, they asked you to drill 2 holes to the fender. Is this necessary?
Its also have 2 "T" brackets (one for each side). According to the manual, the "T" brackets should be mount under or next to the muffler. Is this correct?
Any help would be greatly appreciated. Thanks
