Brake Pad Recommendations? 2006 W164
Old Mar 12, 2009 | 09:22 AM
birjuh's Avatar
2006 ML350
Arrow Brake Pad Recommendations? 2006 W164
Hey all, I did a search to see if I could find some good suggestions for new pads on my car but came up a bit short-handed. I have 34,000 miles on my ML350. This will be the first brake pad change since purchase.
When I went to a private autoshop that exclusively services MBZ, they looked and said I needed front pads and that the rotors looked perfectly fine.
However, when I went to a MBZ dealership, they looked and found that the REAR pads were worn and the rotors showed a ridge.
I will go to another dealership in town to confirm (best 2/3??) because it's sort of strange that the rear ones would go before the front ones.
In either case, does anyone have a good suggestion for aftermarket pads and/or rotors (if it turns out I need them). Also, please tell me what type you have (ceramic, semi metallic, etc).
Thanks ya'll.
Old Mar 13, 2009 | 06:30 PM
AR.Shah's Avatar
2011 E-class coupe, 2012 C-class
Thanks ya'll.
I´ve been pleased with my EBC redstuff ceramic pads, very little brakedust and good braking ability. Remember to get the belonging EBC brake wear sensors as the original don´t work with the pads.
Old Mar 14, 2009 | 07:07 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
Rotex Gold, and the factory wear sensors work just fine with them.
