4 cylinder like idle quality!
Old Mar 20, 2009 | 01:59 AM
akbro93704's Avatar
2014 C250 sport
Does anyone elses ML350 noticeably vibrate at idle? Mainly while in drive.
Old Mar 20, 2009 | 03:52 AM
vinceching's Avatar
2007 ML 500
yes... i've noticed that on all the ml350's i got as loaners.
my 500 does it as well but not as bad as the 350's.
Old Mar 20, 2009 | 07:01 AM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
nope
Old Mar 20, 2009 | 11:49 AM
philip12's Avatar
2008 Ml350
Yes
Yes, my 2008 Ml 350 idle was very rough, after 3 trips to the dealership, (normal) was the answer,,,, one of the service guys said it was not normal, and he adjusted the air flow sensor ( i think) now ,, It is very smooth.
Old Mar 20, 2009 | 02:43 PM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
There is a fix for this. It should be silky smooth at idle. Make sure the dealer fixes it to your satisfaction.
Old Mar 20, 2009 | 02:53 PM
jagass's Avatar
pick up
I think it's just normal...I noticed it too...
Old Mar 20, 2009 | 05:46 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Thank goodness I have a diesel. Smooth and quiet since day 1.
I would venture to say that your vibration is not normal, and can be corrected.
It would just be a matter of finding a dealer with a service writer and technician willing to spend the time.
Post the fix when resolved.
Take care.
akbro93704's Avatar
2014 C250 sport
It's just odd that just the 350 engine in our ML does it...our E350 and C300 are smooth at idle, and theyre the same basic engine as the ML. I dont understand why it should vibrate in the ML but not the others!
I'll mention it when I take it in for service. I hope there is a fix for it, like a couple of you said.
Old Mar 21, 2009 | 08:31 AM
philip12's Avatar
2008 Ml350
mine is smooth now
My description to the SA was, "this car Idles like a lawnmower" he tried to tell me it was normal,,, the idle is fine after the Tech. adjusted some sensor,, after many brands of cars, I think the MB SA's are the worst,
Old Mar 23, 2009 | 06:31 PM
roadrutz's Avatar
'09 ML550
It's an engineering miracle if V6s can be made not to vibrate under any circumstances! Any V6 is inherently unbalanced, unlike a straight six (see BMW) which is inherently balanced. That is why straight sixes typically rev higher than V6s. V6s have to incorporate counterweights and balance shafts to prevent vibration. Balancing has to be done at a specific engine speed, so if it is balanced at idle it could well vibrate at speed, and vice versa. I have nothing but admiration for engineers who can make an inherently unbalanced engine so smooth. Nothing to do with gas vs diesel.
But you shouldn't get any vibration with an ML500 or 550 as a 90-degree V8 is, like a straight six, inherently balanced.
