How Do I Remove the Air Filter
Also, does my car have the charcoal filters?
you run the risk of over oiling and affecting other items
The OEM filters let less small dirt through
K/N has never shown any hp increase in any real world back to back tests.
They spend a lot on advertising to dupe people into thinking more power.
But hey it's your decision
flip over the cover to expose both sides of the filter housings.
To put the hood 90 degrees, push in the red button on the drivers side hood shock and push up the hood. It will lock again at 90.
There are not too many PZEV vehicles in the US, but they are out there. Most people are not aware their vehicle is PZEV or not...but when they realize there is a problem with the fuel pump, they realize real quick. On PZEV fuel tanks, there are no parts available seperate. They are made of metal as opposed to plastic and sealed at the factory. So if your fuel pump fails out of warranty, you will be paying for a new tank.
Screws are on the bottom side of the filter housing.
What is the purpose of changing to the K&N?
The greatest air flow restriction is the air box itself. The filter plays a minimal role at best and then only at the end of its' life.
The air box not only provides the place to hold the air filter but sound canceling and air flow straightening to the MAF.
I use K&N's for the off road vehicles (i.e. not street legal) when only a cold air pipe and filter are desired... not for an OEM replacement.
K&N "may" help for racing/extreme environments - otherwise stay OEM IMHO.
