MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   M-Class (W164) (https://mbworld.org/forums/m-class-w164-72/)
-   -   Help! ML350 Won't Start (https://mbworld.org/forums/m-class-w164/423646-help-ml350-wont-start.html)
kjkimx Nov 18, 2011 02:05 PM
Hello, I just attempted starting my car, and it won't start.
When I turn the key for ignition, engine attempts to start, but it is "stuck" cranking and does not start.
I did leave the car for about 2 weeks, so thought it may be the battery issue, but I am unsure since I've never encountered this kind of behavior before.
Dashboard Lights that are on:
Triangle with exclamation mark
Triangle with car
LIM (ABS)
SRS
Check Engine
UPDATE
Had it jumped using a friend's car.
It did start after a few "coughs" with all the dashlight warnings going away except for the Check Engine light. Check Engine light blinked a few times before it became permanent.
I was able to feel that something was wrong with the engine (weird vibrations).
I let the car run a few min, then turned it off, to see if the check engine light would persist if I restarted it.
Strangely, problem went away when car was restarted - no check engine lights or the weird vibrations.
dgiturbo Nov 18, 2011 06:06 PM
Search around the forum. Have heard of this a few times before and it usually points to the famous cam (or crankshaft) position sensor issue.
aggst1 Nov 18, 2011 06:34 PM
Check your gas cap maybe?
aggst1 Nov 18, 2011 06:35 PM
Never mind the above. I just saw you updated your post.
© 2026 MH Sub I, LLC dba Internet Brands
