Has anyone experienced..............
Old Mar 27, 2012 | 04:52 AM
C-rod's Avatar
2014 ML350 BlueTec.
rattles in the front door pads..................I had this looked at before, and the dealership said it was a tweeter wire that was making this noise....any thoughts ???
Old Mar 27, 2012 | 08:07 AM
zemun1234's Avatar
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
I think I got similar problem on my 2005 E320 CDI. I was in process to change speakers and problem solved. If you ever get a chance to replace non HK speakers, you can see what kind of garbage it is ..It is $50 junk ...
As long as noise in not from front, I am OK
Old Apr 18, 2012 | 01:14 AM
2008ml550_0104's Avatar
08' ML550, ML 63, E55, and 2019 S63, 19’ Porsche 991 911 Speedster
cant say that i have had that problem, i do however get a gridning noise, at slow speeds, where are you experiencing problems with the noises at? high or low speeds? have you had it repaired by a shop recently?
Old Apr 18, 2012 | 07:26 AM
zemun1234's Avatar
Originally Posted by light8008
and I want to know if the tweeter wire cause the problem?
After I replaced speakers, I didn't hear noise anymore ...It could be wire, contact ..whatever ..it is only electrical part in door. When I put speakers, I put attention for every detail and it could be a solution ...
If you want quick solution - disconnect speaker, drive for a few days and see if any difference ...I think it could be quicker than replace speakers and get same problem ...If any problem with speakers, I would put money on tweeter ..
Old Apr 18, 2012 | 11:39 AM
medic's Avatar
2009 ML550
(you will probably get more related answers to your question if the title of your post actually is illuminating, instead of a generic "I wonder....." kinda statement )
