Battery keeps draining - HELP
The guy from the garage told me that it may the hid kit draining the battery but I already disconnected after they replaced the new alternator. I took it back to the garage this morning, and the guy from the garage told me that the draining issue found out "maybe" the rear tail lights.
I was wondering the rear light bulbs already burnt out, how could the tail lamps were draining the battery.
Anyone knows why the battery keep draining if nothing is turn on when the car is parked? I have no alarm installed in the car.
Please help, thanks.
took some time to track it down
they went through and pulled each fuse to see if it would stop the drain
at first they thought it was some other kind of electrical assembly that controls the hatch but replaced that part and it was still draining
pulled that switch and figured out that was the problem
I unplugged the light bulbs sockets before taking the car to the garage and I assume there should not be any electricity running from the headlight wires.
The guys said that even the sockets were unplugged, the battery would still drain due to the cross-wiring of the headlight wiring (before the sockets' portion).
Hopefully, it is the main cause of the battery drain that they have found out and the car can survive for more than a couple of years.
I already spent more than $500 for the diagnosis due to this problem
