Rear Brake Light Warning DIY Fix
Old May 13, 2016 | 04:03 PM
SlimPickins's Avatar
Wife's 2009 ML350 4Matic
Hey all. My wife has a 2009 ML350 4Matic and the rear brake light warning light kept coming on. I know many of us have had this problem and I realize there are a few fixes out there on the web but I wanted to add my 2 cents and hopefully save you more than that! I changed the bulb a couple of times and realized it wasn't a bulb issue. I removed the housing and there appeared to be a compromised or burnt area on the aluminum contact surface for the bulb. It is the small dark area in the photo in the shape of a spade.. I took a small piece of aluminum foil from the kitchen and wrapped it over the area, re-installed the bulb. Good as new and free of charge. I then put a little silicone over the joint where the lamp cover seats thinking perhaps some water had seeped in causing the damage. Just a theory. Anyhow, hope it helps.
For whatever reason, when I upload the photos, they are incorrectly rotated just FYI....
Attached Thumbnails Rear Brake Light Warning DIY Fix-ml-bulb-1.jpg   Rear Brake Light Warning DIY Fix-ml-bulb-2.jpg   Rear Brake Light Warning DIY Fix-ml-bulb-3.jpg   Rear Brake Light Warning DIY Fix-ml-bulb-4.jpg   Rear Brake Light Warning DIY Fix-ml-bulb-5.jpg
Old May 15, 2016 | 04:22 PM
clvincent's Avatar
e320
thanks for posting that
do the 2009 have the rear taillights that leak also? was hoping mercedes had finally solved that issue
