Electric seats not working
Old Oct 10, 2020 | 08:25 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by ML280
Hi
I have a ML280 W164, which had some water damage to the rear SAM, which has now been repaired. Both front electric seats are not working before and after repair. I have checked the fuses and Relay K for voltage with IGN off, ON and with the vehicle running, but I have nothing reading. Can you advise of the next step to resolve this?
Many Thanks
Please UPDATE YOUR PROFILE to include the year and where you live.
Old Oct 10, 2020 | 08:48 AM
ML280's Avatar
2008 ML 280
All updated.
Old Oct 10, 2020 | 10:10 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Originally Posted by Maj. Dundee
When you swapped the two modules, they are coded to that door. That is why they are both not working. Swap them back
I did swap them back then. It was when I swapped back that the other seat, the driver's side, also stopped working. So the fore/aft function is not working on both seats now with their original modules on both seats, when the fore/aft button is pushed there is only a buzzing noise but no movement. All other moves function well; like the leaning of the back, up and down of the seats, and even the headrests function well. It's only the fore/aft function that is acting up.
Thanks,
Old Oct 10, 2020 | 11:43 AM
Hi
Many Thanks
How did you fix the rear SAM problem?
Did you replace both tail lamp seals?
Old Oct 10, 2020 | 11:55 AM
ML280's Avatar
2008 ML 280
When a towbar had been fitted a bolt had been left out where it was near the SAM. A recent very heavy downpour caused water into the area. A bolt has been fitted and no further leaks.
Old Oct 10, 2020 | 02:14 PM
Did water water get into the spare tire area?
Old Oct 10, 2020 | 02:53 PM
  #32
Thanks,
What is the location of these modules?
Old Oct 10, 2020 | 02:56 PM
  #33
ML280's Avatar
2008 ML 280
No, only the area where the SAM is located.
Old Oct 10, 2020 | 03:58 PM
  #34
Did you take the covers off of the SAM and looked at the electrical board for corrosion?
Old Oct 10, 2020 | 04:17 PM
  #35
anavabi's Avatar
The module. in the front of the seat and closest to the door
Just noticed that there's only module under the seat.
Old Oct 10, 2020 | 06:51 PM
  #36
ML280's Avatar
2008 ML 280
The SAM had water damage and I removed the unit and opened to check for any damage. I cleaned the unit myself, but this did not resolve the electric seat problem, so I had it checked by a local mechanic who confirmed it was most likely the SAM. I then sent it off to an Auto electrical repair company in the UK who have repaired and tested the module from the water damage and provided a warranty.
Old Oct 11, 2020 | 01:23 AM
  #37
Did you replace the tail light seals? If you didn't, then water entry will occur again.
Do you have a scanner to check for codes in all modules?
Old Oct 11, 2020 | 09:51 AM
  #38
ML280's Avatar
2008 ML 280
Hi
The gasket's do not need replacing, as they have been checked and the leak was confirmed from a bolt hole left open next to the SAM module. I do not have any voltage to the Relay (K) or the fuses 27 & 28 for the electric seats, with IGN off, on or when the car is running. Is there another Relay elsewhere?
Regards
Old Oct 11, 2020 | 11:07 AM
  #39
With the eng. running in PARK or driver's door open with key out of ign., check fuse #66 in Load Comp. Fuse Box.
Old Oct 11, 2020 | 01:03 PM
  #40
anavabi's Avatar
Major,
Not sure if you're addressing this message to me. If it is to me, there's no fuse 66 on my ML500. Thanks
Old Oct 11, 2020 | 01:46 PM
  #41
ML280's Avatar
2008 ML 280
Hi
I don't have a fuse in 66, here is a photo of my fuse box.
Kind Regards
Old Oct 12, 2020 | 05:36 AM
  #42
You probably do not have that fuse because it only applies to U.S. wiring diagrams.
Things would be much easier if you had a scanner to read codes.
Please post your full vin#.
Old Oct 12, 2020 | 05:45 AM
  #43
Major,
No it wasn't but you should try it also.
Post your full vin#.
Old Oct 12, 2020 | 06:56 AM
  #44
ML280's Avatar
2008 ML 280
Hi
My Vin is:WD01641202A416114
Regards
Old Oct 12, 2020 | 08:22 AM
  #45
Hi
Regards
Please check the vin# again.
Old Oct 12, 2020 | 09:50 AM
  #46
anavabi's Avatar
VIN: 4JGBB75E36A067142
Fuse 66 doesn't exist on my car. Please see attached image for the fuses.
Old Oct 12, 2020 | 11:10 AM
  #47
ML280's Avatar
2008 ML 280
Hi
Sorry WDC and not WDO
Regards
Old Oct 12, 2020 | 11:36 AM
  #48
Posted in error.
Old Oct 12, 2020 | 12:22 PM
  #49
Hi
Regards
According to your vin # you have a 2008 ML350. Confused.
File Type: pdf
Old Oct 12, 2020 | 12:26 PM
  #50
I sent the wrong DATA. Here is the correct one
Give me some time to look through the wiring diagrams.
File Type: pdf
