Electric seats not working
Old Feb 15, 2017 | 03:46 PM
hjaltivignis's Avatar
ML500
Hello everyone, reaching out from Iceland.
I´ve been through so many posts and some of them helped and others did not.
I drive 2006 ML500 and the electric seats are not working. I´ve checked the fuses in the back 27 and 28 i think, 30amps wich are all good as well as two others that might be something to do with the seats. Relay K is also in good condition.
But my driver seat as well as the passenger seat are not working, they do not go back and forth and I cannot move the stall the back either. All other electrics in the car are working as they should. I tried to look for loose wires but can´t see anything.
Has anyone here had similar problems and might know why they are not working?
best regards.
HjaltiVignis
Old Apr 9, 2018 | 10:34 AM
Fusi's Avatar
ML 320cdi 2007
Hello, i have same problem in my ML320 2007, all fuses and relay is ok, i have new Rear SAM modul programmed by dealer, but seat still not working
best regards
Fusi
Old Apr 10, 2018 | 03:21 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
For both of you gentlemen, access the rear SAM in the cargo area and locate conn. G, wire #22 Blue/Red. Turn the key to pos. #2 and test wire for 12v+.
Old Apr 10, 2018 | 05:20 AM
Fusi's Avatar
ML 320cdi 2007
thanks, blue/red wire test are 12 v+
Old Apr 10, 2018 | 05:46 AM
The next step is for this member only as the diagram is different for other models.
With the key on, check both contacts at fuse 62 & 63 in the cargo area fuse box for 12v+. Then check both contacts while someone operates the switch on both front seats.
Old Apr 12, 2018 | 10:12 AM
Hey guys, two members needed help and neither responds. Did you find the problem?
Old Apr 12, 2018 | 10:20 AM
Fusi's Avatar
ML 320cdi 2007
No I have't find the problem yet
I checkt fuse 62 & 63 in the cargo area fuse box for 12v+. And i got always 12volt
Old Apr 12, 2018 | 04:33 PM
And what about the next step:
Old Apr 17, 2018 | 06:56 PM
Fusi's Avatar
ML 320cdi 2007
With the key on, i check fuse 62 & 63 in the cargo area and check both contacts while someone operates both front seats, and the test was 12v+
Old Mar 24, 2019 | 10:33 PM
acko73's Avatar
2007 W164 ML500
was there any updates on this issue, as i am having the same problem
Old Mar 24, 2019 | 10:44 PM
acko73's Avatar
2007 W164 ML500
Hello everyone, and thank you for any and all help you can give me, i own a 2007 ML500 ,vin WDC1641752A222536
for some reason i could never reset my service schedule, eventually it got the better of me, and a freind of mine had access to a MB star Scan tool, so we set about resetting the service schedule, not sure what happened but we ended loosing communication with the Gateway, basically wiped it out, now no indicators, brake lights and other weird things happening, so off to mercedes it goes to be reflashed, all good, till i pick it up from my mates, and i find out now the front seats dont work, and the sterring column wont move either, any ideas of what might be going on???
Old Mar 24, 2019 | 10:59 PM
Scan all modules with Star and post the code numbers.
Old Mar 25, 2019 | 04:57 PM
Fusi's Avatar
ML 320cdi 2007
Electric seat finally working
after advice from the workshop, they changed the rear SAM first, and front SAM module, and also programing, but the seats were
still not working, and then they found a broken relay under the driver's seat and after changing the broken relay, the electric seats start working. So broken reley cost my about 1500 dollars
Old Aug 26, 2019 | 12:58 PM
chiefemilo's Avatar
Ml350 Mercedes 2006
Electric Seats not working
I checked connection G. #22 with key in position 2 and no volts. What could be the problem?
I have a 2006 Ml350
Old Mar 5, 2020 | 05:12 PM
Victor Stephen's Avatar
2008 mercedes ml550
Angry ml550
Hi, I have the same problem 26 27 62 63 k are all good but you said there is a relay under the sets do you remember where and which ones they were
I have a 2008 ml500 and i already spent 500$ with no luck
I need help...
Old Mar 6, 2020 | 04:04 AM
I need help...
No one named ML550 posted on this thread.
Relays under the seat only apply to W163 vehicles.
Old Oct 7, 2020 | 06:51 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Major,
Would you please indicate which relays (on 2006 ML500) belong to front seats. Thanks
Old Oct 8, 2020 | 03:17 AM
M/B does not supply the location of relays K24/1 & K24/2. Possibly under respective seats.
Did you have any water entry in the spare tire area?
Old Oct 8, 2020 | 08:26 AM
anavabi's Avatar
Bone dry everywhere. When the fore aft button is pushed I can hear a buzz but movement. Other movements work perfectly. Also I can't see any relay under the seat.
BTW, the photos don't show.
Old Oct 8, 2020 | 02:07 PM
This doesn't make sense......Bone dry everywhere. When the fore aft button is pushed I can hear a buzz but movement.
Old Oct 8, 2020 | 02:39 PM
anavabi's Avatar
"but no movement"
Sorry
Old Oct 9, 2020 | 04:46 AM
Is it only one seat or both seats? If it's just one, then an object is blocking movement. Remove the bolts on the seat and have a look.
Old Oct 9, 2020 | 10:14 AM
anavabi's Avatar
Started with passenger seat. I swapped the modules with the driver's side, and when I put the modules back, the driver's side also stopped working. Again, only fore/aft functions are not working on both seats. Other functions of the seats work perfectly, even the headrests move up and down with the push of the relevant button.
I have removed the seats, no visible obstruction. As mentioned, when the fore/aft button pushed either way, there's only a buzzing noise from the motor and no movement.
Thanks,
Old Oct 9, 2020 | 01:21 PM
Originally Posted by anavabi
swapped the modules with the driver's side, and when I put the modules back, the driver's side also stopped working.,
When you swapped the two modules, they are coded to that door. That is why they are both not working. Swap them back
Old Oct 10, 2020 | 06:16 AM
ML280's Avatar
2008 ML 280
ML280
Hi
I have a ML280 W164, which had some water damage to the rear SAM, which has now been repaired. Both front electric seats are not working before and after repair. I have checked the fuses and Relay K for voltage with IGN off, ON and with the vehicle running, but I have nothing reading. Can you advise of the next step to resolve this?
Many Thanks
