om642 oil leak
Hi
So the ML has sprung an engine oil leak, seems to be down the left side of sump and int the undertray. Seems to be coming from the front. Turbo inlet pipe is bad and cracked and I just glued it up to keep her running. Dreaded oil cooler? Thanks |
Originally Posted by aussiemercer
(Post 7194128)
Hi
So the ML has sprung an engine oil leak, seems to be down the left side of sump and int the undertray. Seems to be coming from the front. Turbo inlet pipe is bad and cracked and I just glued it up to keep her running. Dreaded oil cooler? Thanks I posted a video on youtube. "OM642 looking for oil cooler leak" - that is the seep hole i am referring to. |
(Post 7194128)
Hi
So the ML has sprung an engine oil leak, seems to be down the left side of sump and int the undertray. Seems to be coming from the front. Turbo inlet pipe is bad and cracked and I just glued it up to keep her running. Dreaded oil cooler? Thanks A good mechanic can use a bore scope to look under the intakes and see the oil cooler. |
Probably.. I had mine done at the dealer for $2200, I asked the dealer to replace the oil cooler too just for the hell of it. Join the MB club and you'll get 10% off.
