W164 steering wheel paddles not operating
Old Jul 19, 2017 | 05:31 AM
Happydays2's Avatar
W164 ML 320 CDI
Does anyone know what would be the problem when the steering wheel paddles do not work?
Old Jul 19, 2017 | 08:17 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Are you referring to the three stalks on the column? Are you saying none of them work?
Old Jul 22, 2017 | 06:38 AM
-AJC-'s Avatar
2006 ML 320 CDI
Think you mean the gear changing paddles?
I have a problem with mine in that both paddles only change up whereas the right should upshift and the left downshift.
Old Jul 23, 2017 | 07:12 PM
dfghhgfd's Avatar
2006 ML500 4JGBB75E56A053890
If you have an older W164 both paddles up shift and down shift on each paddle. One side is up and the other side of the paddle is down, they pivot in the middle. Both on the right and left side of the steering wheel. The later models are one side up the other side of the steering wheel down.
Old Jul 24, 2017 | 01:30 PM
-AJC-'s Avatar
2006 ML 320 CDI
Thanks for this post.
Have just checked mine and they work as described above. Need small fingers to hit the right part of the switch though!
