ML 320 ABS Traction code 5967
Old Jul 31, 2025 | 01:50 AM
  #51
Jibe83's Avatar
ML 280 CDI (DIESEL)
Originally Posted by Maj. Dundee
Did you follow the procedure in the video using a test light?
Forget about fuse *6.
Hola Mayor Dundee, mi vehículo es un ML W164 280 cdi, europeo, tiene el problema 5967, he revisado el cableado, fusibles y he cambiado las escobillas del motor del ABS, he escaneado y borrado errores, pero sigo teniendo los errores ABS y ESP en el cuadro.
¿me puedes ayudar?
Old Jul 31, 2025 | 02:00 AM
  #52
Jibe83's Avatar
ML 280 CDI (DIESEL)
Originally Posted by wannawagon
If it’s just the motor on the flaps you can put a 4.7kohm resistor between two pins to keep the ecu happy and out of limp. Unsure what the Spanish?? Is. Australia
google om642 swirl flap motor delete. You should get a YouTube eventually
Si, es el motor del ABS, ¿donde he de colocar la resistencia?
Old Jul 31, 2025 | 02:02 AM
  #53
Jibe83's Avatar
ML 280 CDI (DIESEL)
Perdón no encuentro el video !!!!!!!!
Old Jul 31, 2025 | 02:07 AM
  #54
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
Sorry. Don’t understand all the spanish.
can’ t remember which fuse blows. Five years since I did it
But if you replace the fuse and it blows you will need to unplug and put the resistor in harness to ecu. Can’t remember which pins but will be on YouTube
Old Jul 31, 2025 | 02:17 AM
  #55
Jibe83's Avatar
ML 280 CDI (DIESEL)
El fusible no se funde, simplemente no se borra el error del cuadro de instrumentos tras poner las brushes del motor eléctrico del ABS.
Old Jul 31, 2025 | 02:18 AM
  #56
wannawagon's Avatar
I just googled om642 swirl flap delete and there is heaps of info.
Old Jul 31, 2025 | 02:45 AM
  #57
wannawagon's Avatar
Don’t think there are any fuses for the abs motor.
