Odd sight when screwing the oil filter cap off
Old Nov 5, 2017 | 10:47 AM
Rauhbatz's Avatar
2007 ML 350 - VIN 4JGBB86E17A211020
Question Odd sight when screwing the oil filter cap off
Changed the oil using my new gizmo, a Mityvac oil extraction device. Love it!
When I went to change the filter I found a condition I have not seen before.
The filter cap came off but the rest of the filter tower remaining in the oil filter housing. To avoid undue headaches I screwed the cap back on so I could use the vehicle today.
The filter tower was in the housing w the old filter...but it did not come out when removed the cap.
Its been a while since I changed my own oil but I can't recollect that ever happening before.
Old Nov 5, 2017 | 12:33 PM
ItalianJoe1's Avatar
2003 CL 600
You can pull the filter out, the remove the center piece and clip it back into the cap.
Has it been a long time since you last changed it? Sometimes the o-rings stick in there.
Old Nov 5, 2017 | 07:36 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It's condensation build up usually caused by short trips.
Old Nov 6, 2017 | 09:44 PM
Rauhbatz's Avatar
Thanks for the insights!
Hi Tony...I didn't see a clip on top of the cap for the post to clip into...but will look again. O rings look OK. It was just odd to have the cap come off and not have the post attached to it.
Mostly shorter trips these days w the ML...anything long distance becomes an airline trip!
