Rear rotor on my ML350 2010
Hi Guys
I plan to change My rear rotor and brake Pads.
I want to buy the right one and I see a lot of ; Fit Models with Solid Rear Rotors
Is this will fit ?
I can provide my Vin number if it may help
+ Do I need only 1 sensor or 2 ?
Thanks !
Is this will fit ?
Thanks !
Here are the part numbers for the pads, rotors & wear sensor. Only one sensor on the right rear. Also other parts that you might need.
Since you are replacing the rotors, it might be a good idea to replace the parking shoes. Make sure you use Brake Caliper Grease on #350 slide pins.
Here is a copy of your DATA sheet.
