2014 ML350 brake replacement
Old Sep 13, 2018 | 09:43 AM
spw's Avatar
spw
2014 ML350
ML350 needs rotors and pads. What should I be paying at the dealership today?
Old Sep 13, 2018 | 11:37 AM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
probably 800 for front rotors and pads
Old Sep 13, 2018 | 01:43 PM
spw's Avatar
spw
2014 ML350
Thanks, Just heard from the stealership. Four wheels $2100.
Old Sep 13, 2018 | 02:14 PM
kombifan's Avatar
Wowza... ask your dealership if they do rack rates on labor.
Maybe you can bring in your own performance parts and save some
Old Sep 13, 2018 | 09:06 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
How do you know you need rotors? Curious as I have a '14 ML350 with 44k on it. I was expecting to have the rotors turned and new pads installed when needed.
Old Sep 14, 2018 | 11:27 PM
lkchris's Avatar
'10 CL550, '12 GL550
Rotor “turning” is not permitted by Mercedes and in any event your rotors will very likely be worn beyond the wear limit anyway.
The wear limit is 2 millimeters ... find a metric tape or ruler and observe what one millimeter is. Then feel to see if you have a lip at the outer edge of your rotor ... if you do it’s very likely 1 mm and of course there’s another one on the back side of the rotor. Even if you’re slightly under the limit, your rotors will still be worn over the limit before a new set of pads is worn out. You can measure with a caliper of course, but you’ll need one that will “go around” the lip.
Basically, brake work on these is pretty much always new rotors plus new pads. This is by design and yes it’s different than chebbies.
You can save a LOT of $$ doing this work yourself, but you do need some big tools. You can obtain genuine parts much cheaper from Merc dealers selling online, and in fact brake rotors are parts included in Mercedes’ “ Star Parts” program, which are economy versions of the real things. Dealer example I use because it’s close: mbdirectparts.com
Your 2014 is a W166 of course.
Old Sep 15, 2018 | 08:25 AM
pjw1967's Avatar
Thanks. Yes. A W166. Very useful info. I was surfing around youtube for DIY videos. Came across the emergency brake release issue. I also have a '14 GL450. So if I don't screw up the ML, I'll get a second use out of the tools.
Old Sep 16, 2018 | 07:54 AM
Rauhbatz's Avatar
2007 ML 350 - VIN 4JGBB86E17A211020
Too much $
Mine averaged $250 a wheel for rotors and pads
Old Sep 16, 2018 | 07:13 PM
pjw1967's Avatar
For just the parts?
Old Sep 16, 2018 | 08:42 PM
Rauhbatz's Avatar
Was $1600 for all 4 wheels - parts and labor
So figure $400 w wheel
Old Sep 18, 2018 | 09:43 AM
DanD.'s Avatar
2018 GLC 4MATIC
There are no issues with emergency brake, it must be in service position
watch this vid it will tell you how.
And here is the front
Old Nov 18, 2018 | 03:56 AM
MBenz777's Avatar
2013 ML 350 BlueTec
Wooow that an interesting number! You can do it yourself for less than $500 is an not very complicated job and if you take your time and educate yourself viewing some youtube movies it will not take more than 2-4 hours for all wheels.
Old Jul 20, 2023 | 12:16 AM
1aJose's Avatar
ML 350 Bluetec, Toyota, Chevy
Any advice on how to change the front brake calipers and bleed the system on a 2014 ML 350.?
Thanks.
Old Jul 21, 2023 | 04:35 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Thanks.
Whats wrong with the calipers? Do you need to change the calipers or rotors and pads?
Old Jul 21, 2023 | 10:03 PM
1aJose's Avatar
Front brake caliper
R F was leaking but I cached it early and successfully replaced it today, not much fluid leaked out and pads not oily. Other parts are good, only 40ooo km on the brakes. Car has 140ooo km. Thanks for the reply.
