need to know if my benz has keyless go?
Old 10-09-2018, 03:48 PM
Vegasml's Avatar
2006 ml500, 2000 ml430, 1999 e320
ok sounds like a dumb question but I just got the car, its a 2006 ml500 and the driver door lock actuator dosnt work so I need to know if its keyless go or not so I don't order the wrong part. When I touch the door handle the door unlocks but I don't know if that's a keyless go thing or if they all do that, it didn't come with a push start button but I know that's removable. so if they all unlock by touching the door how can I figure out if its keyless go or not?
question 2.. anybody know where I can get that door lock actuator for the best price?
Old 10-10-2018, 04:59 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If you touch the door handle and the door unlocks, you have KeyLess Go.
If the door unlocks, why do you want to replace the door lock actuator? Confused.
Post your full vin#.
Old 10-10-2018, 09:51 AM
bha
bha's Avatar
13 GL350, 14 SL550
As Maj Dundee said, if you touch the handle and it unlocks, you definitely have keyless go. It can be confirmed by VIN, but I'm 100% sure you have it.
Non-keyless go cars will not do anything when you touch the handle.
You definitely need a keyless go door handle. Also order a push button as they're reasonably cheap and you can just plug it in. No need to use keys at all in your truck.. touch the handle to open (or lock) and push the button to start. Key can stay in your pocket all the time!
Old 10-10-2018, 02:09 PM
Vegasml's Avatar
Thanks guys. The vin is 4JGBB75E26A048520. It’s the door lock actuator I need to replace because the driver door will not lock. I can’t push the lock down either. I am having a hard time finding the keyless go actuator and don’t want to spend 600 for it at the dealer
Old 10-10-2018, 02:35 PM
bha
bha's Avatar
13 GL350, 14 SL550
Buy a used one on eBay or from a wrecking yard. I believe most (70% or possibly more.. should ) of the Ml and GL models in the US had Keyless Go.
Just make sure the vehicle had Keyless Go and it will fit. Get the VIN if you can and we can tell you for sure.
BTW I looked up your VIN and your vehicle does have Keyless Go listed as an option
Old 10-10-2018, 02:37 PM
bha
bha's Avatar
13 GL350, 14 SL550
Just looked on eBay and found this for $140. It has a VIN listed, and when I looked up the vehicle, it had Keyless GO installed. So I think this should work fine for your car:
https://www.ebay.com/itm/MERCEDES-W1...qhgS:rk:3:pf:0
If that link doesn't work, it is eBay item # 163277275668
Old 10-10-2018, 02:40 PM
bha
bha's Avatar
13 GL350, 14 SL550
Have you considered the fact that you might need only the replacement spring? These trucks are known to have bad actuators and it is the spring that fails. You can buy a kit of four springs for less than $20 and repair your own actuator.
I think much of the labour is removing the actuator so it shouldn't be hard to fix it and put it back in. Also that way you are guaranteed to have a compatible part (it will be a big problem if you take the door apart and the new actuator isn't the right part)
http://vi.vipr.ebaydesc.com/ws/eBayI...1&secureDesc=0
ebay # 161960674750
Old 10-10-2018, 08:35 PM
Vegasml's Avatar
Thanks everyone, I bought that actuator on eBay saved me over 400 bucks. I didn’t think it was the spring because it’s not doing the ratcheting thing the lock is just stuck, I could be wrong. But thanks again everyone you guys are a very helpful!
Old 10-11-2018, 05:31 AM
Here is a copy of your DATA Card. Notice that code 889 is present, KeylessGo.
File Type: pdf
S.O.B (12-30-2020)
Old 10-11-2018, 05:47 AM
Which one did you buy? Post the link.
According to your vin#, you must buy part #164 720 11 35.
Old 10-11-2018, 04:00 PM
Vegasml's Avatar
I bought the one in the eBay link from bha
Old 10-12-2018, 05:33 AM
You were requested to post the link. How are we supposed to know which one youchose.
Old 10-12-2018, 01:53 PM
Vegasml's Avatar
Old 10-13-2018, 02:27 AM
The part number on the lock you bought does not fit your veh. You ordered the wrong part.
Old 10-13-2018, 03:29 PM
Vegasml's Avatar
Vegasml's Avatar
Is that right?
Old 10-14-2018, 09:25 AM
Is that right?
How can that be the right part # ? You need 164 720 11 35.
Old 05-19-2019, 11:20 AM
dewhurst90's Avatar
A180 Sport Premium
What website do you use to find this info out, im getting an A180 this week Used but not 100% sure what features it actually has, would be good to know.
Old 05-19-2019, 06:54 PM
You have to post in the A Class forum, depending with the year.
Old 03-18-2020, 10:09 PM
69armando's Avatar
2011 mercedes e350
Does my car have keyless go 4JGDA5HBXDA127691 2013 ML350 I do have keyless entry
[QUOTE=bha;7574131]Buy a used one on eBay or from a wrecking yard. I believe most (70% or possibly more.. should ) of the Ml and GL models in the US had Keyless Go.
Does my car have keyless go 4JGDA5HBXDA127691 2013 ML350 I do have keyless entry. I tried putting push button from my S and GL, but nothing.
Old 03-19-2020, 04:50 AM
[QUOTE=69armando;8011510]
Yes you have Keyless Go. Code 889.
File Type: pdf
Old 03-19-2020, 06:10 AM
69armando's Avatar
2011 mercedes e350
The vin is
the VIN # is- 4JGDA5HBXDA127691 can verify for me and thank you in advance.
Old 03-19-2020, 07:20 AM
[QUOTE=69armando;8011624]What does this mean? I have already informed you that you have Ketless go.
Old 09-08-2020, 06:14 AM
nishu nishad's Avatar
2010
Keyless entry and push start
Dear i want to know wether my vehicle have keyless go option
vin :
Old 10-29-2020, 01:08 AM
S.O.B's Avatar
ML 350 2007
4JGBB86E77A228422 Good day wonderful people. Thats my VIN as displayed; I'd like to know if my ML350 has keyless entry. Thank you.
Quick Reply: need to know if my benz has keyless go?
