Ml350 intermitant no start no fuel pump prime
Old Nov 1, 2018 | 02:10 AM
BRENDAN BURKE's Avatar
2006 ml350 petrol v6
G'day All? I am new to the forum and hope someone can point me in the right direction. My 2006 petrol Ml350 has an intermitant fuel pump issue in which for no reason won't prime the fuel pump upon turning on ignition. I replaced the pump after I discovered the no prime issue. I had power and earth at the connector when switching the key on. All went well for a couple of weeks then the problem appeared again. I removed the rear fuse box and found a burnt pin on the top connector which was the feed wire to the pump. It has obviously been drawing to much current because of the bad pump. I disassembled the fuse and resoldered any dry joints on the fuse box pcb and replaced the bad terminal. All seemed good for a couple of weeks and then it failed again so I replaced the rear fuse box, again it worked for a couple of weeks. I have checked the wiring harness connector under the vehicle inspection cover and it all seemed good. I'm sorry for the lenght of this post but I'm trying to give as much detail as possible. If any learned members have any solution that would be wonderfull. Thanks Brendan
Old Nov 1, 2018 | 03:20 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What year. Please UPDATE YOUR PROFILE in USER CP to include the year, 350 Gas or Diesel and where you live.
