air intake manifold part
Old Nov 10, 2018 | 12:28 AM
2011 ML 550's Avatar
2011 Mercedes Benz ML550
I recently had a P0106 error code on my 2011 ML550. So, I changed the hose, clean the MAP sensor, then re-connect the MAP sensor hose to the air intake manifold, but on the process I unknowingly pry off the plastic component (that's should not be removed) that is attached to the intake manifold and broke 2 of the 4 leg type that hold it inside the intake manifold. I went to local car parts store and couldn't help me where to buy the part. So, I went to Mercedes dealership and was told that the plastic part is sold together with the whole air intake manifold. I was thinking that if that parts can be accidentally pry off, then somebody should have a replacement parts for that. Any suggestion will be a great help.
Old Nov 10, 2018 | 02:39 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The intake manifold must be removed to replace the aftermarket replacement which is metal instead of the original plastic ones.
Old Nov 10, 2018 | 03:08 AM
Thank you, Maj. Dundee. I searched around and got 2 options. 1.) Go to a pick-your-part (junk yard), look and remove that plastic port seal from the air intake manifold, and 2.) Use a JB Weld to securely stick the plastic port seal to the air intake manifold. Thank you for your input. Do you happen to know where to buy the aftermarket plastic port seal?
Old Nov 10, 2018 | 03:46 AM
What plastic port seal?
