Ever replace the rear liftgate handle?
Old 12-08-2018, 04:23 PM
Rauhbatz's Avatar
2007 ML 350 - VIN 4JGBB86E17A211020
The plastic liftgate handle on the rear door is really starting to stick. To the point where I use a flat blade to put it back so the gate latch will lock. Likely the result of Ohio winters throwing crud up into the license plate area.
I have sprayed it w PB Blaster, carb cleaner as a few other things trying to get it to spring back...no luck
My daughter used the handle, left the liftgate ajar and caused the battery to run down...even after I told her to use the key fob or the left door switch that triggers the lift gate...college kids... :o
Was curious if anyone has replaced this plastic liftgate handle or has another remedy to get it to spring back
Old 12-08-2018, 04:48 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP to include the year and model of your truck and where you live.
Then post your full vin# as the correct handle depends on the chassis number.
Old 12-09-2018, 06:27 AM
Rauhbatz's Avatar
Done! VIN entered in CP....
Old 12-09-2018, 07:33 AM
Check the vin # again. It is supposed to be 17 characters. I think you left out the G....4JGBB
Where you live.
Old 12-09-2018, 09:12 AM
According to you DATA Card, you have auto tailgate open and close. Why have you not mentioned this?
Why does you daughter use the outside door handle when she could use the remote?
File Type: pdf
Old 12-09-2018, 10:43 AM
Rauhbatz's Avatar
Too early of a flight today...yes I left out that elusive G.....all good now
Old 12-09-2018, 10:45 AM
Rauhbatz's Avatar
It was one of her fellow college students and her that used the lift gate handle thinking it was just like another liftgate.
Me I use the interior left door control and the remote
Old 12-09-2018, 12:27 PM
Well what happens when you use the remote to open and use the button on the door to close?
Do you still want to change the handle?
Old 12-09-2018, 01:19 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
I had that issue on my w163 ml. Spraying with lots of wd40 helped.
Rauhbatz (12-10-2018)
Old 12-10-2018, 07:24 PM
Rauhbatz's Avatar
Both work well...its just natural to put your hand on the liftgate to acutate it
Old 12-11-2018, 04:41 PM
bha
bha's Avatar
13 GL350, 14 SL550
Mine started sticking a few years ago. Not as bad as yours, but once in a while you couldn't shut the hatch because it thought someone was holding the handle open.
Took off the panel inside and lubed it with heavy silicone grease. Found out that you can actually lube it better from the outside than inside.
I would spray it clean (brake cleaner etc) then put a thick coating of silicone grease on it. Keep working the handle and reapplying till it stops sticking. Then wipe off. After a week do it again and leave a very thin coating on at the end (to protect from water/salt/etc.
It may start working again.
If not, you'll need to remove the interior panel (not hard) and replace the handle. If I recall correctly the handle just had two bolts and then unhooked from the linkage easily. Most of the work was removing the interior panels etc.
Old 12-11-2018, 07:31 PM
Rauhbatz's Avatar
Im going to try the brake cleaner then silicone process..see how that goes.
Old 12-22-2018, 05:03 PM
Rauhbatz's Avatar
Wd40 is the magic juice!
Lift gate handle works great
thanks for the tips!
Quick Reply: Ever replace the rear liftgate handle?
