2011 ML350 Bluetec Filter housing gasket
Hi everyone, I think my filter housing gasket is leaking where it attaches to the cylinder head. Has anyone had this problem? It leaks from that particular area, drips down and then the fan blows the oil all over the underside of the engine and belly pan. There is no evidence of oil coming from the valley (read oil cooler). I tried using a mirror as there is a space you can look from the underside of the oil filter housing. It is definitely coming from that area, I just wasn't sure if there is a cam seal or cam seal cap behind there as well that could be leaking. Anyway, if anyone has replaced this gasket before please let me know or if you have the directions, even better. Thanks in advance.
Rick
Rick
Jfxogara (02-13-2022)
I need to do this job also.
Thanks.
Paul
