Front right inner turn signal stay on always
Hi every one
I have problem with my ML350 bluetec 2010 which is front right inner turn signal stay on since 6 months
I checked the following items ;
1. The right harness E2e5 stay +ve always so I loose the sleeve and check it toward the cockpit nothing wrong or contact
2. Open the right head light connect it to the left harness the signal off and normal working , I disassybled the head light every thing ok
3. Disconnect the hazard botton , it still the same
4. Checked front ,under seat and rear SAM all fuses and relays ok
5. Disassybled the steering combination control nothing wrong with it
6. I live in Iraq - Mosul there is no technicians have experience with new mercedes cars so I check it by my self
please help my to solve this problem
waiting your kind urge
please accept my greetings
THANKS 😁
Front right inner turn signal stay on always even when car off
E2e5 +ve always even when car off
THANKS 😁
Plutoe
Dear Sir
Thanks allot for your kind reply
I did removed all the relayes in the engine fuse box and the rear SAM and the signal stay on !
Is there any relay other than engine fuse box or rear SAM ?
Waiting your kind reply
Thank you Sir
Thank you Sir
Based on your VIN I reviewed the turn signal actuation circuit and found the turn switch request is passed to the central gateway module to the front SAM which, through microprocessors provides the on\off voltage to the turn signal lamp. There are no relays or fuses in the circuit.
I believe that you have a faulty SAM and this can all be confirmed with an MB XDOS short test. I have no other comments on the subject!
Plutoe
Thanks a lot
May I ask
Why only the inner signal stay on ?and the outer one not !
May I ask
I am not a software engineer and can't answer that question. That is why the most important point of my previous message is on line three,the last four words.
Mission completed 😊
Today I reached front SAM after removed passenger seat , as you instruct me removed connect C wire 31 was clean , so I disassybled the SAM I found some salted areas as in attached photo , I clean it with white spirit , dry it and reconnect it
It work 😂
But right SRS warning light on !
Any sujjestion ?
Thanks a lot for your support am greatfull to you
Oh wow! I have exactly the same problem with my 2011 Ml 350. I'll remove the passenger seat and test for voltage later today. So happy to find this post. Thank you so much guys!
When I removed the front SAM and the battery, this is what I see. Any ideas why I see the yellow sticky stuff on the floor?
Anyway, I found the problem on the front SAM that caused the turn signal light stayed on all the time. The problem was here: (Thank you for all your help, all the information you guys contributed!)
Then I used WD40 electrical cleaner, Q-tips, and rubber alcohol. After all the cleaning, this was how the board look:
And the problem was fixed! No more turn signal light staying on all the time
