2008 ml320 rear sam burned and damaged wires in trunk
Hello:
I have a 2008 ml320 cdi. I need the complete harness set (wires) for the rear sam (passemger side in trunk) where the sam is located and the fuse box. Mine burned completely and i am repairing it. i had ordered a refurbished oem rear sam due to water leak damage (behind the tail lamp) replaced it and out of nowhere while the car was parked after 2 weeks fire started in the trunk (fuse and sam side - passenger rear) fortunately i turned off the fire and the car is fine but the wires and all have burned out completely. it would be very sad to let the car go as is for no money. I rather fix and drive. I need the complete wire set in and out of both sam and fuse panel (box). Can you help on where i could find the complete wire set ? https://cimg0.ibsrv.net/gimg/www.mbw...51947601f.jpeg Thanks. Ps: i have attached a pic any advice would be appreciated. I have cleaned it out so the pic is before the cleaning. |
You need to find a salvage yard that will let you remove everything you need from a donor damaged vehicle.
Yes thats a good idea.
However having the salvage remove it and sell it to me would be fastest. Any website ? I am currently overseas. Also the salvage might be very far from me. Thanks for your advice. |
Check car-parts.com and search for a sam. Call them and see if they will sell your the wiring harness.
Thanks much 🙏🏼
I will call them. |
I just checked they dont have any ML option. I assume they dont have any ML in their inventory. Any other site ?
Originally Posted by Kampefem
(Post 7781391)
https://cimg0.ibsrv.net/gimg/www.mbw...412859f63e.png |
ok i will try again.
its just that when i select mercedes model, the ML does not show. |
(Post 7782008)
its just that when i select mercedes model, the ML does not show. If you're on mobile or tablet make sure "Desktop Site" is checked on Google Chrome. The mobile site of car-part.com lists only 170 million cars and a limited list. The desktop version lists 200 million cars and the full list. |
Yes i was on mobile.
will check from pc. will let you know. |
Brother i dont know how to thank you.
you were right. although they dont have it listed but i made a request that was sent to many. i hope it will work. 🙏🏼🙏🏼🙏🏼🙏🏼 God bless always. |
(Post 7782257)
you were right. although they dont have it listed but i made a request that was sent to many. i hope it will work. 🙏🏼🙏🏼🙏🏼🙏🏼 God bless always. No worries, hope everything works out! |
Again thank you but wanted you to know that
Unfortunately its been a few days and nothing from car-parts i wanted to post this so you and everyone reading my post known that i do not yet have found. So i am still lookig for solutions. 👍 |
