Ml350 2010 humming noise when radiator fan plugged in
Old Jul 4, 2019 | 07:28 PM
Andycanon's Avatar
Ml350 bluetec
Hi all,
I read up on some humming noises here but was unable to find one that matched my problem.
I recently replaced my radiator fan and as soon as I plug the socket into it I hear a humming electrical noise that comes from the center of the engine. As soon as I unplug it again it stopped. But as soon as I plug it in it comes back on right away.
Any ideas? I was wondering if it was a relay but didn't know what fuse or relay controls the radiator fan.
Its linked for sure to the radiator fan that I'm 100% sure. And the fan and ac work great again.
Thank you.
Old Jul 5, 2019 | 04:47 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Remove the plastic eng. cover and see what is making the noise.
Old Jul 5, 2019 | 08:17 AM
Andycanon's Avatar
Ml350 bluetec
Of course, t
It's hard to pin point the noise but it seems like it's coming from around the fuel pump area. I only heard it click off once but then it comes back on again. Its non stop.
But again as soon as I unplug the radiator fan it stops.
Old Jul 5, 2019 | 12:27 PM
Then you probably bought an aftermarket fan which can have wiring problems.
Old Jul 5, 2019 | 12:35 PM
Andycanon's Avatar
Ml350 bluetec
What do you mean? What kind of issues could it have inverter connectors or something?
Old Jul 5, 2019 | 12:45 PM
Exactly.
Old Jul 5, 2019 | 12:48 PM
Andycanon's Avatar
Ml350 bluetec
Exactly.
Do you think its wise to try and invert them my self and see what happens?
Old Jul 6, 2019 | 04:16 AM
Compare it to your old one wire for wire.
