Need Help with 08 ML W164
Old Oct 15, 2019 | 01:56 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Originally Posted by Maj. Dundee
Your vin # shows that you have Parktronic so look for a connector that will plug into it.
It really bothers me that I post a separate question and you did not respond. What's the next plug #?
I apologize for that, the reason i didnt respond to it is that i didnt have it at the time needed to go to the garage and get it was planing to do it today and i did.
2 of the male plugs got same part # 012 545 71 28
1 female plug #0374 545 73 28
From what i see its door sill led Mercedes light it lights up when you open the door. but i might be wrong.
My Gateway module came back cloned. i can read my codes now. 1 code was P0170 fuel trim bank 1 and another one was U0100 lost communication with ecm/pcm A
i deleted them and see if it will come back later ill check after work
The SRS light i didnt check yet i will do it later.
I dont see nothing in the back to plug in that parktronic connector to maybe im missing a module or something?
Old Oct 15, 2019 | 02:43 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
This number has too many digits......#0374 545 73 28
Old Oct 15, 2019 | 04:43 PM
IgorE350's Avatar
Made a mistake 037 545 73 28
Old Oct 16, 2019 | 05:37 AM
Is this connector this image ? If it is, isn't it connected to another connector? If it is what is the part number?
Old Oct 16, 2019 | 05:57 AM
The previous information on 029 545 55 28 was an error in location. Here is the correct location and it is the connector for the Parktronic Display on the rear roof.
Old Oct 16, 2019 | 07:20 AM
Please double check this number as it does not show up for your vehicle.
