Rear SAM Symptoms
Old Feb 28, 2020 | 04:52 PM
  #51
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Originally Posted by Maj. Dundee
Did you erase all codes in all modules?
Yes i did go in to every module and erase them all. Only these came back so far
Old Feb 29, 2020 | 01:55 AM
  #52
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
But are these 3 things working properly?
Old Feb 29, 2020 | 01:45 PM
  #53
IgorE350's Avatar
Sunroof seems to work fine, keyless go unlocks when i put my hand inside the handle but it doesn't lock when i put my hand on top of the handle or when button on handle pressed.
and power liftgate obviously doesn't work, soft close works.
Old Mar 1, 2020 | 03:35 AM
  #54
Did you or anyone else work on the left rear door?
What do you mean by "soft close"?
Old Mar 1, 2020 | 10:33 AM
  #55
IgorE350's Avatar
That i dont know, got the car few months back with water damage. left rear door locks and unlocks fine with keyfob or buttons inside, but i do get the error code.
I meant soft close on rear liftgate. when i close it by hand not all the way the actuator will pull it and close it all the way
Old Mar 1, 2020 | 11:35 PM
  #56
Dinismb's Avatar
2005 Mercedes C230 Kompressor, 2008 GL 320 CDI, 2008 ML320 CDI, 2016 GLE 300d AMG Night Package
Originally Posted by anavabi
Thanks Major. As I mentioned on my post, the fault codes I sent are from Front SAM. Rear SAM had no fault codes. Are you still suspicious of the Rear SAM?
My buddys tail lamps backup lamps and license plate lamps wont turn on. I did a scan with mbii and got the codes respective to not working lights. i also got a rear sam code. So i opened and took out the rear sam and seen some corrosion on a few connectors. I went ahead and ordered him a new rear sam and will install it tomorrow.
Since youre not getting a rear sam code than it should be fine.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
