Engine stall, P0335 Crank Shaft Position Sensor A
Old Sep 22, 2019 | 08:33 PM
dkgcb's Avatar
2006 ML350
Exclamation Engine stall, P0335 Crank Shaft Position Sensor A
I have an issue where the engine just stall in the middle of driving, basically all dashboard lights come on and the car shuts off.
I try to start engine but nothing. It just cranks but does not start. After about an hour, the car starts again.
I checked for codes and noted p0335. I read other posts where people suggested replacing crank shaft position sensor A and I will do that, however I'm wondering why would it start again after an hour, it appears as it has to do with the engine cooling off. Would the sensor overheat cause it to mulfunction or is this a simptom of something else?
Any thoughts?
Old Sep 23, 2019 | 07:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Yes, after it cools down it will restart.
File Type: pdf
File Type: pdf
File Type: pdf
