Radiator replaced hose that screw in leaking
06 Mercedes benz Ml500
I just recently replaced a bad radiator. The hose/lines that screws in to the upper right side is leaking. I need the name of that hose to replace it. Or does it just need a gasket?
It was the O ring
Thats exactly what it was the O ring that was originally on there was worn. So i took the O ring that came with the radiator,and vuala no more leaks. Thank you
