ML63 engine issue
Old Apr 21, 2020 | 09:10 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
That part is available with the hose, approx. $25.
Old Apr 30, 2020 | 03:37 AM
Leeroy AMG's Avatar
ML63
Thanks, it arrived today. Any ideas on how to get the grommet through without breaking it? The rubber is quite firm and not easily pinched or moulded. I tried for 2 hours today but no luck. I will try a hose clamp tomorrow to work like a piston ring compressor and see how that works but I’m very reluctant to use too much force!
Old Apr 30, 2020 | 04:45 AM
That hose end does not look like the hose end that broke off.
From who did you buy that hose?
Old Apr 30, 2020 | 05:05 AM
Leeroy AMG's Avatar
ML63
It was purchased from MB.
Old at the top, new at the bottom. I can NOT get it through in either direction.
Old Apr 30, 2020 | 08:59 AM
Leeroy, it's a push in piece. Lube the front piece with Vaseline and push it in.
Old May 10, 2020 | 09:10 PM
princemarko's Avatar
CL63, 2014 ML63, 2008 ML63, R500, GLK
Originally Posted by Leeroy AMG
Sorry, it’s the inlet manifold. The Centre plate being the middle plate on the intake manifold
where the throttle bodies attach.
company makes aluminum ones to fix that RMT I think
Old May 10, 2020 | 09:14 PM
  #32
Leeroy AMG's Avatar
ML63
Yes you are correct. There’s a few (probably all same manufacturers) worked perfectly.
Now just to fix all the other parts MB butchered from previous times with the manifold off.
