2007 ML63 AMG W164 Engine Tapping sound
Old Mar 19, 2020 | 07:59 PM
Kieran Murphy's Avatar
Mercedes ML63 AMG W164
Hi I've have a ML63 AMG W164 2007 with 90,000miles. Full MB Service History... Ive had this problem for a while, this problem occurred when I had a leaking injector and camshaft sensor failed, petrol was dumped into oil, that all been sorted now but since then I started it and I now hear a tapping sound from engine it gets louder and faster when I accelerate. I've search few places saying it could be the lifters, camshafts but also got told it could be a bent rod. Can someone please help me..
Old Mar 20, 2020 | 01:48 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You can see what is necessary in this recent thread. But you must know what you are doing.
https://mbworld.org/forums/m-class-w...ml#post8010071
Old Mar 20, 2020 | 07:36 PM
I started it again tonight, puffing white smoke out of exhaust and cover whole estate with smoke the tapping has stopped after a drive last night. And it's used 6litres of oil
Old Mar 21, 2020 | 01:33 AM
Kieran, if the eng. is blowing thick white smoke, you need professional help. It is an indication that a cylinder head is cracked or the head gasket is faulty, which means that the eng. is burning coolant along with fuel.
And they will tell you that your eng. must be replaced.
AMG are the hardest engines to work on.
Did the eng. ever over heat?
Old Mar 21, 2020 | 11:46 AM
The smoke clears after the cars been on idle for about 5mins the car has never over heated in its life I've had it since new from Mercedes, the coolant stays between 80-100⁰c and oil is between 90-110⁰c
Old Mar 21, 2020 | 12:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Kieran, when the whole estate is covered with white smoke, this is an example of a major problem.
Possibilities are a significant leak of oil or coolant.
What does the smoke smell like?
Old Mar 21, 2020 | 12:50 PM
it smells like burning oil I've checked the coolant and has never used any
Old Mar 21, 2020 | 02:10 PM
I also have no indicators, wipers, no interior lights when doors open, and dosent lock or unlock and air suspension, and boot does not open and fuel gauge dosent read, in the passed I have changed front and rear sam due to condensation. I hope the rear sam dosent need changing again. But on the Maxisys MS908 pro Diagnostic machine its saying rear sam not sending any data all wires are plugged in I took it apart and no corrosion, I kept it inside for 1 night to get room temp and still does not work.
Old Mar 21, 2020 | 02:41 PM
These other things that are not working are the least of your problems. The engine problem must be addressed first.
Did you replace the tail lamp seals when the rear SAM was replaced?
Old Mar 21, 2020 | 02:43 PM
Yeah I did change seals
Old Mar 21, 2020 | 02:44 PM
I'm going to sell car how it is as the engines they want are over £12k and I do have someone who will fit it but cant find cheap one
Old Mar 21, 2020 | 03:32 PM
good luck on your next car.
Old Mar 21, 2020 | 03:42 PM
thanks next car will be an M5 getting that next week
